 Mako Discussion
 1997 232 Bracket Replacement Help
tvclaw
Posted - 05/14/2018 :  22:03:17  Show Profile  Reply with Quote
I am considering replacing my 1997 Mako 232 factory bracket with an Armstrong bracket. Has anyone out there gone through this project and, if so, any recommendations or suggestions? Looking for someone reputable to remove the old bracket and replace with the Armstrong. I have recently repowered with a Honda BF 250 and need more floatation on the back. I live in New Jersey. Thanks!!
Shif
Posted - 05/16/2018 :  21:54:48  Show Profile  Reply with Quote
I am considering the same motor on my 96 232, obviously the weight was too much on yours. CAn you advise as to what the actual issues are?
Holgatelbi
Posted - 05/17/2018 :  12:54:01  Show Profile  Reply with Quote
Not sure where in NJ you are, but Ken at NuWave Marine in the Deptford area has always done me fair.
856-232-6969
They do excellent fiberglass work & mechanical. I guess the bracket falls somewhere within that range.
1984 Mako 228 w/ 175hp E-Tec
1983 SeaRay 26' Sundancer w/ 454 Big Block spinning Volvo DuoProps (Sold)
1989 Wahoo 17' CC w/ 88hp Evinrude (vacationing in Key West)
ddd222
Posted - 05/17/2018 :  20:03:07  Show Profile  Reply with Quote
I would also go with a name brand bracket also like Armstrong or stainless marine, although I do like some I have season custom from a and j. That being said I would also try to mimic the exact degree negative trim or slightly positive trim that the factory bracket came with.Someone should be able to duplicate that down a degree or two with new bracket and wedges if needed
ddd222
Posted - 05/17/2018 :  20:04:33  Show Profile  Reply with Quote
some I've seen
This page was generated in 0.52 seconds. Powered By: Snitz Forums 2000 Version 3.4.07
