 Mako Discussion
 TROLLING MOTOR ON MAKO 224
Previous Page
Page: of 2
1985Mako224
Posted - 03/14/2019 :  13:56:24  Show Profile  Reply with Quote
Got it thanks! You can send them to me directly if it's easier. 941-713-08 seven nine. I appreciate it!
Dustin
1985 Mako 224 w/ E-tec 250hp
St. Pete, FL
surfishjoe
Posted - 03/15/2019 :  08:02:10  Show Profile  Visit surfishjoe's Homepage  Reply with Quote
Nice some action! I measured the bow using a leveled straight edge coming off the water line at 40-41" so yeah a 60" may work but the 72" will be better especially offshore. I am getting parts list together and am starting to feel the expense of the system and its a big one. Im thinking 2 AGM mighty max 75 ah batteries in boxes, 15' of 6 gauge duplex wire and associated terminal hardware, 50 amp breaker, pro mariner 2 bank charger, battery tender plug, and the unit. Looking like 3 large at least. Then comes the fun part of figuring out how to mount it. I see you used aluminum and starboard. I was thinking using a slab of 1/2' starboard inside the anchor locker as a backer plate, then a starboard pad on the deck to raise the base even with the bows tow rail lip. If I have to relocate the lights I was looking at those Taco rubrail lights more $$. I also have to figure out my dock situation because I slip the boat at a fixed dock and use the front cleat and chocks. At low tide the bow sits well below the level of the docks tie points so the motor may have to come off the boat every time I tie up. I guess that is a bridge I would cross at a much later date. Still trying to figure out how to finance this system. Decisions. Thanks for the pics and info keep em coming. The kicker is this will completely rewrite fishing for me and open up so much more so I know its worth the expense.
Margate NJ
1989 Mako 211
2009 Etec 200 HO
Edited by - surfishjoe on 03/15/2019 08:11:34
explrgab
Posted - 03/15/2019 :  09:36:39  Show Profile  Reply with Quote
SURFJOE...ALL OF YOUR POINTS ARE VALID....THE DOCKING COMMENTS ARE ON POINT. IF YOU WANT I CAN SEND PICS TO YOUR PHONE OR EMAIL...OR SHOOT THE BREEZE ABOUT IT. IF YOU WANT TO CALL ...I SENT PICS TO 1985MAKO224. HE LIKED THEM....
EXPLRGAB 224/221
PORT ST LUCIE, FL
explrgab
Posted - 03/15/2019 :  09:38:10  Show Profile  Reply with Quote
I HAVE THE RUB RAIL LIGHTS...THE OTHER ONES HAD TO GO.
EXPLRGAB 224/221
PORT ST LUCIE, FL
surfishjoe
Posted - 03/17/2019 :  08:39:57  Show Profile  Visit surfishjoe's Homepage  Reply with Quote
yes please to more pics ! surfishjoe at aol.com
Margate NJ
1989 Mako 211
2009 Etec 200 HO
explrgab
Posted - 03/18/2019 :  07:50:43  Show Profile  Reply with Quote
SURFJOE...DID YOU GET THE PICTURES..VIA EMAIL?
EXPLRGAB 224/221
PORT ST LUCIE, FL
snappergapper
The Freshman!
Posted - 03/18/2019 :  23:47:05  Show Profile  Reply with Quote
Send them ton) 386-45one ten53. Thanks. I would love to come down and fish it.offshore with you.
1984 Mako 224
1977 Mako 15
Clermont, Florida-
http://www.classicmako.com/forum/topic.asp?TOPIC_ID=37212 -Rewire
http://www.classicmako.com/forum/topic.asp?TOPIC_ID=40627 -Tank/Misc
http://www.classicmako.com/forum/topic.asp?TOPIC_ID=58615 - Aft Box removal
explrgab
Posted - 03/19/2019 :  08:49:31  Show Profile  Reply with Quote
BEST TIME TO COME MAYBE WHEN SNOOK COME IN HARD...THEN YOU CAN MANEUVER AROUND AND INTO DOCKS AND SEA WALLS ON THE TM AND THEN POST UP.....OFFSHORE WILL BE TO TAKE ADVANTAGE OF THE BOTTOM BITE WHICH I AM STILL EVOLVING INTO...ONLY BEEN HERE 15 MONTHS......COBIA ARE HAPPENING NOW...MUTTON SNAPPER LATER...I ALSO HAVE IT IN MIND TO POST UP ALONG WEED LINES USE LIVE BAIT CHUM...AND OR SLOW TROLL FOR MAHI
EXPLRGAB 224/221
PORT ST LUCIE, FL
Page: of 2 Previous Topic Topic Next Topic
Previous Page
This page was generated in 0.53 seconds. Powered By: Snitz Forums 2000 Version 3.4.07
